Is it possible for you to add a task dialog as found in Vista?
Jørgen Storlie
Vista TaskDialog
Taskdialog Dll
I have created a TaskDialog just to test if it work.
Maybe I will create a plugin, but the dll seems to work.
Currently I have made this interface:
ShowRadioButtonQuestion:
Radiobuttons is a comma separated list
Return values are:
0 if you select NO
201,202.... if you select on of the radiobuttons
The dialog works on all windows versions.
Jørgen Storlie
cbTaskDialog.dll
function ShowInformation(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowWarning(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowQuestion(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowRadioButtonQuestion(Title : PChar;Instruction : PChar;Content: PChar;Radiobuttons : PChar): integer; stdcall;
Return values are:
0 if you select NO
Jørgen Storlie
cbTaskDialog.dll
Many thanks for this great DLL!
I have moved the topic to the Plug-Ins forum.
Users browsing this forum: No registered users and 5 guests
