Can it be done? I'm trying to set up my Web Block in such a way that instead of pointing to the actual target file(say, www.whereever.com/downloadthis.7zip), it will point to an ASP file that will return the url for the file.
Though, when I try to run the installer, it crashes, citing an inablilty to extract the data from the file downloaded.
So, CAN asp files be used in this way? Or do I HAVE to reference 7zip files directly?
Ta much.
Using .asp files wth Web Blocks?
mws,
You do have to reference the 7zip files directly.
Alejandro Ronquillo
Users browsing this forum: Google [Bot] and 18 guests
