Hi Guys,
I'm currently packaging the HP/Mercury version of your Screen Recorder software. (I'm guessing you must've resold it to them as it's exactly the same).
My issue is that I'm trying to create a silent installation to be distributed via MS SMS in a enterprise environment. I've tried using all the normal MSI silent switches but none of them seem to work? Can you please advise on your silent switches?
Failing that, you've included a driver installation exe: DrvInstaller.exe Is there a silent switch for this or can you provide the raw driver files?
Kind Regards
David Johnstone
Coles Ltd
Silent Installs
David,
I am not sure if you are talking about InstallAware here, but if you are, here is the answer to your question:
To run a silent instalation just run your installer with the /s parameter.
Alejandro Ronquillo
Installaware branding
He thought it was your software because of the branding that you put on the install screens
Thanks for clearing this out Ted.
Alejandro Ronquillo
Users browsing this forum: No registered users and 11 guests
